跳转到主内容
Is it my Catalytic convertor
I ran out of gas (one time) and my car would not run after that. The fuel filter has been replaced, fuel pump replaced, spark plugs replaced, and gas tank removed and cleaned. It is still not running right and the check engine light is blinking. I filled the tank and put fuel injector cleaner in it. Is it the catalytic convertor.? If so can it be cleaned or must it be replaced? Could it be something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Does it smell like rotten eggs? Does it run hot all the time. If so, you should have a good mechanic check it out soon. If you wait to long it may damage the engine.
完成的
添加一条评论
1个答案
已选择的解决方案
Ryan, Have a good technician scan/check your vehicle for trouble codes as a first step in trouble shooting the engines performance problem. A good technician can run test to see whether converter is bad rather then throwing expensive parts and labor at it. There are lots of things that could cause engine to run bad , vacuum leaks, plugged EGR,faulty injectors, faulty coil, etc., have it scanned.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 50
