跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Rear Camera replacement halp
Purchased the Iphone 7 and the apple battery case. Decided I didn't like the iphone 7 and went to take it back to the store. As I was taking it out of the case it dropped and smashed the camera. I was basically told that I now get to pay for a phone that has no camera and they will not take it back.
When will replacement cameras for the iPhone 7 be made available?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
What do you mean "smashed the camera"? Is the lens broken or did the camera module itself break?
完成的
The replacement cameras are available now from Chinese suppliers, so I would expect to see them on the market in the US soon.
完成的
Not sure if its the camera or just the lense cover, I've ordered the iFixit kit so I can open the phone and see what is actually broken.
完成的
Post some photos once you get inside so we can see what you're dealing with.
完成的
Can the rear lens be changed without opening the phone? Does it just pop out?
完成的
显示更多的3条评论
添加一条评论
6个答案
已选择的解决方案
I just replaced my GF Damaged Lens
First remove the screen as the ifixit Guide
Then remove the rear camera (2 screws) and pout pops the camera. Them carefully remove the camera holder (pain to remove without twisting etc but i straightened it out afterwords)
To remove the lens pop it out with a pen or something similar. Now add some glue i used E8000 frame glue and them put in the new lens and added the camera holder and put back in the camera.
Now i added a new screen seal i used a iPhone 6s as i cant find any ip7 ones yet.
Put the screen back on and all done :)
这个答案有帮助吗?
得分 3
3条评论:
Where did you order the lens from?
完成的
okay several questions. Where did you get the lens cover? I basically destroyed the part that you said you were able to bend back.. so where do I get that?
完成的
https://www.ebay.co.uk/itm/172361778981
I can't help with the bracket as mine didn't break so didn't needn't to replace it,
Perhaps try the iPhone 6 bracket
https://www.ebay.co.uk/itm/161742502454
Not sure if it will fit yet as still early days with the 7. You don't have to replace the bracket if you can't the camera will still be held in place by the top cover you screw back on, just make sure the lens glue is set before putting the camera back in otherwise it will glue it in haha.
完成的
添加一条评论
About 3-6 months, I would guess
这个答案有帮助吗?
得分 1
添加一条评论
you need iPhone 7 rear camera replacement? here it is http://www.etradesupply.com/apple-iphone...
这个答案有帮助吗?
得分 0
添加一条评论
Hi I got it from eBay UK
这个答案有帮助吗?
得分 0
添加一条评论
Same problem for me, there is a problem with the lense I think
这个答案有帮助吗?
得分 0
添加一条评论
Hi im using the b7000 glue is it good and the adhesive seal do i leave the hole $@$* in the phone.
Btw is this goood https://www.ebay.com/itm/291916233746
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
j weir 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 8,495
