跳转到主内容
加入维修社区 - 创建账户
由 Blackberry 设计,并于 2011 年由广达电脑制造的迷你平板电脑。型号为 RDJ21WW。
Charger receptacle problem - unit can't charge
It appears that when I connect the charger cord the juice doesn't flow to the battery. The battery icon doesn't indicate that the connection is occurring and the cord end doesn't fit properly any longer in the receptacle. Help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It may just be that your outlet is not working. Here are 2 videos that explain how to reset gfi outlets and breakers. It is very easy to do. Tap on or click on the blue links to see the videos. If this is the problem you will be able to do it easily. I hope this helps. Good luck!
https://m.youtube.com/watch?v=trLeLJdMWW...
https://m.youtube.com/watch?v=OUR0GBrDmS...
这个答案有帮助吗?
得分 0
1条评论:
I tried t charge in many different outlets which all worked for other items, so I'm still unable to charge the unit. Thanks for your answer anyway
完成的
添加一条评论
添加你的答案
Jb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 830
