跳转到主内容
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
20 个问题 查看全部
ideas for parts on dmg 1 gameboy
i have a corroded main board. any ideas for parts
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
@coleeau depends on where and what is corroded. You can try and clean the corrosion but without seeing what you danage you have, there is no way to suggest any parts. Post an image of what you see with your question. Use this guide 在已经存在的问题里加入图片 to post images.
完成的
@coleeau take some closer images of the actual board. We need to see if the traces are still intact.
完成的
i got a main board on ebay.
also the gameboy was tested and confirmed not working.
thanks anyways
完成的
添加一条评论
1个答案
最有帮助的答案
Since the device is confirmed not working, take a moment and test out something. The best way to clean the corrosion off of metal is to soak it in a shallow bath of distilled white vinegar. The blue corrosion should bubble and be removable in a few moments.
Clean it with a toothbrush and then give it a shallow bath in rubbing alcohol. Once you've done that, again, clean it up with the toothbrush and see what kind of damage you have to the traces and components. It could be savalagable or completely scraped but worth the good learning experience.
If you have time, give it a shot and see what happens. I'd be interested in finding out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jake Donovan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 173
