跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
MacBook Pro RAM replace
Hi all,
I want to replace my ram (4GB) from my MacBook. I checked the model of the rams in my laptop and they're 1333mhz. I read that my model could work with 16GB, is this true or is the maximum 8GB?
Can I use 1600mhz instead of 1333?
What brands are known for good quality?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I have previously installed 16GB RAM on this model and an SSD and together they boost the speed of that model tremendously.
You want to be careful about investing a lot in them though since this model is prone to VGA failure and Apple will only be covering this defect until end of 2016.
I personally recommend these RAM modules.
这个答案有帮助吗?
得分 3
3条评论:
So will 16gb work on my model? And not 1600mhz but 1333?
完成的
Let me try to explain things here:
First, yes your system can support 16 GB of RAM. In fact the system I'm using right now is the same as yours with 16 GB of RAM.
As to the speed of the RAM I do recommend following Apples guidance here following there T/N: MacBook Pro: How to remove or install memory. I would put in the 1600 MHz modules.
完成的
Like Dan said, 1600MHz are supported, but the 1333MHz are good as well and from their description you know the ones I linked will work with the model you have.
完成的
添加一条评论
添加你的答案
Uas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 120
