跳转到主内容
加入维修社区 - 创建账户
The LB7 Duramax is a 32-valve V8 diesel engine produced from 2001-2004.
crank no start: no codes, no fuel at primer, rattle from engine
2002 6.6 lb7 Duramax will not start. Engine was making rattle sound. Sounded almost like a sheet metal vibration but RPM sensitive, coming from low in engine.. There are no codes. Not getting fuel at primer bleed off. no signs of water in fuel. Thanks, Terry
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
These trucks have an injector pump that's driven off the main timing gear. It's in the front of the engine in the valley. So if you heard noise coming from under the hood or front before it stopped running and you have no fuel pressure now while cranking it sounds like your injector pump took a crap. What u can do to verify lack of fuel is get a small rag and wet it with gasoline not diesel and hold it infront of the throttle body. My buddy has a twin turbo duramax and I've helped him pull the motor a few times and he's showed me a few little tips n tricks. A few drops of gas should start it up. U also can check the fuel rail for pressure with a gauge but if u don't have 1 on hand the gas rag can confirm no fuel.
这个答案有帮助吗?
得分 0
添加一条评论
broken crankshaft...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Terry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 40
总计 1,653
