跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Backlight on LCD not working
I saw several other people in this situation but no one actually answered the question I have.
Like many I got water damage... my question is if I replace the display assembly, will the backlight be replaced as well?
I have a black iPhone 3GS 8GB A1303.
You can see the display fine in sunlight but if I go into a room or low-light environment I can't see the display at all.
The display is working fine, just the backlight is out.
Any thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
There are 3 places where damage may stop backlight - LCD, connector1 prongs on mainboard or the backlight coil itself which is on mainboard. Replacing LCD doesn't always cure the problem... There are a few good links on here about how to repair your coil ( James bond I think) . I would try cleaning the phone thoroughly with isopropyl alcohol first- you may have residue spoiling connections
这个答案有帮助吗?
得分 1
2条评论:
The downside to that is I am currently stationed in Korea, so getting isopropyl alcohol isn't something feesible right now.
完成的
anything high content alcohol is all you need. 90% alcohol leaves 10% water, so the higher the % the better. you could just open the phone and try a soft brush to get rid of debris. many people refer to it as "rubbing alcohol" try that at the pharmacy/chemist...
完成的
添加一条评论
yes, it will be replaced, but it would be sad to pay that much if you could replace a couple LEDs or similar. If you do replace the displace assembly I would be more than happy to acquire your old one for the touch screen component if nothing else.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Ballentine 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 9,749
