跳转到主内容
7" multimedia tablet by Barnes & Noble, released in November of 2011. Fixes are easy and require simple prying tools and screwdrivers.
20 个问题 查看全部
I forgot my password
how can i reset my nook u ? i forgot my passcode
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
3条评论
Where is the answer I need this help with mine
完成的
Power on and once you see read forever press and hold power button until it offers off. Repeat this 8 times and the nook will clear and reset to factory image them go into settings and factory reset
完成的
I tried this and it did not work---was on phone with support for 1 1/2 hours could not help me either---
完成的
添加一条评论
2个答案
已选择的解决方案
kimberly, how can i reset my nook u , 3rd link gives clear instruction on how to do factory fall back, just make sure nook is plugged in when doing fall back. Check the attached links,instruction and guides, Good luck.
https://www.youtube.com/watch?v=4_Rw_kue...
https://print.nookpress.com/forgot_passw...
https://bookclubs.barnesandnoble.com/thr...
这个答案有帮助吗?
得分 4
添加一条评论
Hi Kimberly,
This website might be able to help you:
https://www.techwalla.com/articles/how-t...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kimberly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 46
总计 34,712
