MacBook Pro is only charging with 0.1-6.2 Watts
As the title says, my MacBook is only charging with low wattage, there are two screenshots from coconutBattery attached.
It might have something to do with battery, as the computer was not used in almost a month. A service provider has tested every component and they said it is a faulty battery.
Have any of you had this problem? What did you do to fix it?
Update (10/04/2016)
Apparently, the problem is within the logic board, the computer was dropped before and I guess some connections could have broken.
4条评论
Then it sounds like the SMC charging logic is damaged here. Time for a visit to the local Apple Store or authorized service center.
由 Dan 完成的
Hi @mortigisto , did you fix your problem? Im having exactly issue on my MacBook Pro Early 2011.
Thanks for help
由 adrilkf98 完成的
Sorry, mate, gave up on it a while ago, and purchased a new Pro.
Good luck with yours, though!
由 Kventin Shipulin 完成的
I have the exact same problem, 2013 MacBook Pro Retina with 60W charger. In coconut I get a max of 6.16 watts. I bought a new charger but problem is still there. Did you find a fix for this? I noticed the problem after upgrading OS with Opencore Legacy Patcher, but I don't know if this is related.
由 Philip Thorn 完成的
