跳转到主内容
加入维修社区 - 创建账户
Acer Iconia One 7 是一款于 2014 年 4 月发布的平板电脑。 Iconia One 7 是一款小巧精致的娱乐设备。它配备了一块比平板手机更大、既清晰又色彩鲜艳的显示屏,响应迅速,且拥有长久的电池续航时间,可满足你的日常使用需求。我们还内置了 Kids Center 平台,提供大量有趣的儿童内容,并允许家长进行管理。
black screen - can't use it.
hello everyone,
I just needed some help with my Acer Iconia one 7 B1-770. I hit the display brightness/darkness at its minimum and found out I can't see nothing at all. I thought there might be issues with low battery but when I pressed the volume, I could hear any sound. Unfortunately, I cannot use my tablet anymore.
Does anyone could help me how to fix this issue??please.
Thanks & God bless.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Hello, have you tried a factory reset? Follow these steps:
1. Power off the tablet.
2. Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3. While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
4. Once the tablet screen turns on, stop holding the buttons.
5. On the Android system recovery screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
6. When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
7. Select reboot system now.
由完成的
My acer 10 tablet was stuck in black screen after disabling the boot from boot option properties. didn't start up the windows after turning it on.
由完成的
添加一条评论
2个答案
I had a friend bring this issue to me…
turns out the brightness was just down to zero..
so pull down from the top of the tablet twice.
then about 1 and a half centimeters down just try to use your finger and catch the brightness slider and slide it to the right again and voila… working again.
这个答案有帮助吗?
得分 0
添加一条评论
How to fix my acer ipad black screen with grey lines
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Renalie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 5,481
