跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 个问题 查看全部
Add a SATA HDD to late 2013 iMac that has PCI-e SSD?
iMac Intel 27" late 2013
OK, having search through most of the questions it seems that users would most often like to upgrade their hard drive to a solid-state drive using the standard SATA connector.
I've read that system with factory installed SSDs have the require PCI-e slot, but if originally equipped with a HHD, the logic board doesn't have that port available.
In my case, I have a late 2013 27" iMac with the PCI-e SSD, but want to add an internal HDD. Did Apple build this logic board with a SATA port for that? I would assume the SSD only and Fushion drive iMacs used the same board, which means it should, but I was looking for someone with a bit of experience with this chassis to confirm it before I begin dissembling it.
Lastly, if so, will this unit require the same temperature adapter as earlier iMac's when using non-Apple sources HDDs?
Thanks so much!
Update (09/29/2016)
Any thoughts, or was this a dense question?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
It's a A1419 so this guide should work:
iMac 因特尔 27" Retina 5K 显示屏 硬盘更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 473
