跳转到主内容
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
34 个问题 查看全部
After powering, the programmes simply flicker and crash on opening
The system started up successfully(windows 8) but programmes/ softwares installed refused to open in the desktop environment. when clicked to open, it flickered and went off. The touchpad also didnot respond well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,
Try connecting a USB mouse and see if the programmes open alright. The thought behind this is as you say that you are having problems with the touchpad I'm wondering if it may be double or triple 'tapping' due to a faulty touchpad and therefore closing the programme as soon as it opens.
完成的
添加一条评论
1个答案
Check your bios and change it to factory defaults. Turn it off and replace the CPU Thermal paste as per manual if you aren't competent enough have it done at a computer repair shop. Also have the air intake cleaned of dirt and pet dander/hair. Then try to power it on again since it is now an aged system. ( I have the same model and it runs fine after cleaning and Thermal paste replacement.)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
EfJay Adiakpan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 32
