跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
leftover part after disassembly
iphone 3g 8 gb
I have a leftover] small piece
(~1cm long) of metal with a screw hole after disassembly] and I am trying to figure out where it goes. I do not see it in the tear down pictures so I am assuming it must have come off during the disassembly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Here's the teardown, do you see the part? iPhone 3G Teardown
完成的
添加一条评论
2个答案
最有帮助的答案
it will be camera holder. place it on the top of the camera, the hole facing to the right, there is a screw hole without the screw. put it there...
这个答案有帮助吗?
得分 1
1条评论:
would you back that up with a link to a picture?
完成的
添加一条评论
Check out the top right hand of the pic where you see the are marked 'E' that is where the piece go's (on top of the camera assmebly)
http://i54.tinypic.com/5oypm1.jpg
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kuria 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,109
