跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
installing lcd assembly from 1 a1181 to another model
will any a1181 lcd assembly (top case, bevel, screen and camera) work in any other a1181? could I use an lcd assembly from a 1.83 with a 2.4?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
If the
manufacturers part numbers (on the backs of the LCDs) match no problem...
这个答案有帮助吗?
得分 2
添加一条评论
A1181 models can be Core Duo or Core 2 Duo processors. I believe the LCDs are indeed interchangeable but the Core 2 Duo have 3 antennas for the Airport Wifi, but the Core Duos use only 2 antennas. The antennas are in the LCD lid assembly. Therefore you will have no problems if you replace the LCD of a Core Duo with LCD of a Core 2 Duo, but not if you're doing it the other way around.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the detailed response. I was asking specifically about the LCD assembly, which to me, means the lcd,the front bevel, the backing plastic and the web cam
完成的
I have an A1181 Core 2 duo and I only have 2 Antennae. It all depends on the exact model.
完成的
添加一条评论
I have installed the three antenna models but had to exchange the wiring from the old one to the new one or you can change the airport card to the vise versa. They are interchangeable.
这个答案有帮助吗?
得分 0
添加一条评论
The Airport cards are interchangeble as well. If you have three cables just connect the outer two. If you have a card with three connectors and only two antenna cables connect them to the outer two sockets and leave the inner one blank.
The actual display panels are the same throughout this range of Macs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,253
