跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
iMac 27 Late 2015 - Black Screen After HDD Replacement
Hi all,
I've replaced the hard drive and thought I had no problems until I tested the unit before reassembly, essentially I get the start up sound , fan and hdd whirling but a black screen. There are four indicator lights but only three are on. This is my first Mac upgrade so criticism is okay. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
已选择的解决方案
Since this machine was under warranty, why are you into it in the first place?
这个答案有帮助吗?
得分 0
2条评论:
Had to replace hard drive.
完成的
Since this machine was under warranty, why are you replacing the hard drive and voiding your warranty?
完成的
添加一条评论
Try reseating the display connector, if it doesn't work, you may have damaged something in the process as you said that it is your first time, and this is a hard repair. Try plugging it into an external monitor if you have one. If you can't get it up and running try to put everything back together as original as you can and bring it into an Apple store and see what they can do as it must still be under warranty.
这个答案有帮助吗?
得分 0
5条评论:
I don't see any ports for an external monitor, just USB and Ethernet.
完成的
it should have a thunderbolt port. It is a little square-almost trapezoid that has a lightning bolt near it.
完成的
Okay, I see the thunderbolt port, now I have to get a cable that goes to HDMI. Question: what do you suggest I do if there is output to the external monitor?
完成的
If you have another Monitor you can connect with thunderbolt - mini Displaybort to VGA or DVI Adapter. You can order them from Apple online store
完成的
try to restore it to factory conditions (minus the problem) and take it to an apple store of an ASP and play dumb.
完成的
添加一条评论
添加你的答案
StaceyK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 2,024
