跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Distortion when using headphone
I've got an iPhone 5s and when I plug in my headphones, there is an awful distortion. I replaced the headphone jack/lightning assembly with the same result. The problem is that if I don't push the headphones in all the way, they sound fine. It's just the last "click" where it goes wrong. Anyone have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Alex, Try a different set of head phones, making sure it is compatible with your I phone, some of the connection tips vary in size and shape and yours sounds like it is not making proper connection.
You can also try this at your own discretion, with a pair of pliers bend the tip on head phone pin slightly and try.
这个答案有帮助吗?
得分 1
添加一条评论
Use toothpick.
Also use a ear-swab (with some alcohol).
Then see if you can get the sprig out in the proper position.
It is probably stuck. That's the piece that holds the plug in place.
You should see it when you look inside with flashlight and magnifier.
这个答案有帮助吗?
得分 0
添加一条评论
I already replaced the jack so it shouldn't be an issue. I'll give it a shot either way.
这个答案有帮助吗?
得分 0
添加一条评论
I'm having the same issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,187
