跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
Seagate Hard Drive Model ST380011A
Hey THere !!!
i messed up with mah described above ... actullay i pushed that IDE cable a bit harder ... :| ... n broke one pin mmm actually two pins ... one on the uper row n other on the lower row ... i dont know what to do know .. mah hard drive is not detected ... i used some metal pins n tried to put them in place of the broken pins .. only 1 out of 10+ attempts ... the hard drive ran .. n detected ... n showed all the data .. but then ... the pins displaced n .. again it vanished from the screen ... atleast here i know that only those broken pins are ^!^^@@^ mah hard ... so is there any ... way i can fix them ? like :D ... mah dear hard again gets alive ? :( plz help ppppp .... thanx in advance :) ...
P E A C E !!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
with mah hard drive ****
完成的
http://i867.photobucket.com/albums/ab235...
here is the link .. for further assistance .. you can see the red circles ... showing the broken pin spaces ... so .. plz help :) .. thanx
完成的
添加一条评论
3个答案
已选择的解决方案
I know of no one that has ever been able to fix this type of broken pin problem. For that matter no one that has ever used enough force to break them. Bent yes but not break. Sometimes things are just beyond repair.
这个答案有帮助吗?
得分 2
1条评论:
agreed +
完成的
添加一条评论
What palokiller said, but chances of success could be slim depending on the age, model, and condition. Personally, if there isn't anything valuable on the drive, chuck it and buy a new one. They're too cheap now a days to waste a ton of time on an old one.
这个答案有帮助吗?
得分 1
添加一条评论
i would try to get exactly the same harddrive, preferably one with clicking noise failure and try to replace the electronic board.
quite frankly, just bin it and buy a new one...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gambler881 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,931
