跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36478 个问题 查看全部
no audio after fixing broken screen.
So i broke the screen twice now =( that's not the issue at hand.
I replaced the lower dock,speaker,mic assembly and my iphone had audio for about 3hrs then it went away again.
It was very staticky and such, songs would play but sounded like they were skipping on a scratched disk.
I have tried everything that I know of please help. Will provide more info as requested.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
From what I have come up with its the 'light' sensor flex cable that also handles the audio to the ear piece. I crushed my iphone in my hands the other day trying to replace the whole audio system so now I am back to my sony ericson. Replace the #3 flex cable, if you make a call 'to your own house phone' place your hand above your ear piece speaker and if your screen doesn't shut off like it should that's the cable that needs replaced. At least someone has a solution to the problem even if its at my expense :(.
Droid X here I come.
这个答案有帮助吗?
得分 1
2条评论:
+Thanks for getting back with your solution
完成的
Can someone please tell me how exactly do I do this I rlly need to know??
完成的
添加一条评论
This fixed my problem too. I noticed that ringtones were working fine, but I had no sound otherwise and my silent switch had no effect. No vibrate either even when toggling in the settings screen. The cable had popped loose when I put the antenna cover back on after replacing a broken screen. Reconnected the connector and it worked perfectly.
这个答案有帮助吗?
得分 1
1条评论:
This is exactly what happened to me. Carefully reconnected the connector (and putting that dreadfull antenna back into place) and screwed on the protector to keep it in place and it worked!
完成的
添加一条评论
I had the problem after a screen replacement. I notice the the vibrator that sits under the logistic board wasn't flat and making a good connection. I went and straightened that up and made sure the copper prongs on the loud speaker was clean and making a good connection. I hope that this helps someone. I was at my wits end.
这个答案有帮助吗?
得分 0
添加一条评论
I've cracked the top of my phone so the sound works to listen to videos but if i wanna call someone i can't because the sound does not work
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
addictive blahblahblah 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 58
总计 21,050
