跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 2009 won't turn on
My MacBook Pro won't turn on, also there is no blinking light on MagSafe charger LED.
I tried a new charger (same model) nothing happened, and also I tried a new A1322 battery from the original 10.95v 60w to a newer 10.95v 63.5w unit.
The first time MagSafe light blinked green only for just a second then again off, I tried SMC reset, unplugged the RAM but nothing happened.
I'm from Sikkim India. In our state we don't have any Apple Store
Please help
thanks
Update (09/11/2016)
http://www.everymac.com/systems/apple/ma...
Thank you so much dan'
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Please supply your systems info. Plug in your systems S/N here: EveryMac - Lookup then paste the URL of your system here so we know what your system is.
I suspect you have a deeper problem here than the battery.
完成的
Finally !problem solve.. after motherboard repair its works fine .. thank you all ,
完成的
添加一条评论
2个答案
已选择的解决方案
Have you checked the DC-In Board where the MagSafe Power Adapter connects? Check, if the connect-pins are ok or maybe clean that with alcohol pads.
If you have a spare DC-In Board try to replace this and give it a test.
If that doesn't work, then you have to start with the minimum configuration:
- disconnect everything from the logic board except the fan and keep the DC-IN Board on the logic board
- plugin the MagSafe (it should turn on the green LED)
- then connect the power pads on the logic board and check if the fan turns on.
If yes. The logic Board is ok. If not, then the logic board is faulty and has to be replaced.
IMPORTANT: Please do everything with ESD Tools and use a ESD Anti Static Mat and Anti Static Wrist Strap!!
Let me know if I could help you with this advice.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Try disconnecting the battery and the magsafe adapter , press and hold the power button for 15 seconds. Hook it back up and try powering on and let us know any results you get.
这个答案有帮助吗?
得分 4
1条评论:
Thanx Machale,I tryed no thin happend !
完成的
添加一条评论
添加你的答案
Kailash gurung 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,027
