跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Replacing Back Case And Bezel
Hello. My name is John and i'm thinking changing the back black case of my iphone with a new, white one. I would like to know, if i can replace the back case alone and use the factory metal bezel (scratched as is), or i necessarily need to buy new bezel to complete the re-assembly? Another thing i would love to know is what parts (buttons, etc) can be moved from the old into the new case and what parts i need to replace with new (are irremovable). For example, the little protective grids at the bottom that cover the mic and speaker must be replaced or they are integrated in the dock connector and . That kind of details i would like to know in order not to mess the whole thing up. Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
you can replace all the old part/buttons into the new cover.
the bezel is held on with a glue which you will need to dig out from the little tabs which snap on to back case. (i don't know which glue others may use-I didn't use any and the finish is ok. don't use superglue as this melts the plastic)
the microphone and speaker covers aren't integrated so you'll need to use a small screwdriver to pop them out (tiny bits of fiddly mesh-don't clean the glue off you'll need it to stick them in the new case)
you may also have to push out the silver rings from headphone jack and camera lens to complete the look depending on whether they come with your case.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
john 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,048
