跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Data Recovery Broken iPhone
Somebody please help! I recently dropped my iPhone into water and when I pulled it out, it was black and the dot next to the front facing camera was red. I haven't backed up any photos since March and I really need the pictures I have taken since then. I've tried software to recover them, but most won't recognize my phone when I plug it into my PC. How can I get it to recognize my iPhone? I seriously need those pictures. Somebody please help!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Hi there,
Tom Chai is right, in order to access your data/photos, the phone has to be semi-functional.
Water damage can be pretty nasty; it causes corrosion on the boards and shorts your circuits. Your best bet is to read and follow the steps on these guides in order to bring your phone to life enough to recover the photos: 修复iPhone 的进水故障
Electronics Water Damage
Good luck!
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
Repair the original phone to the point that it can boot up, unlock and connect to PC via USB, or have wifi so you can back the data up through wifi. Other than that, nothing else can bring back the data.
这个答案有帮助吗?
得分 4
1条评论:
i agree with Tom ... unfortunately if you cannot the the original logic board to work, the data inside is lost :(
完成的
添加一条评论
Can you connect your old phone to your PC with USB now? If you could, maybe you could try to use data recovery software to help you to recover your data, including photos, contacts, etc, from your phone without any backup. if you are a iPhone users, read this article to learn how to recover data from water damaged iPhone, while read this to know how to if you are a Android phone user, try to find other related article of this website to help you based on your situation!!!good luck to you.
这个答案有帮助吗?
得分 0
添加一条评论
Best advise for future - do a backup! iCloud is super comfy for apple devices.
About extract the data- try this
They helped me ones, after i dropped my iPhone in the pool , phone is dead but i have all my contacts and photos at least.
这个答案有帮助吗?
得分 0
1条评论:
It was written in 2016
完成的
添加一条评论
It may be some hardware related causes, you should check the connector first. Here is a guide on how to recover data from a water damaged iphone. Hope it helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lydia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 505
