跳转到主内容
加入维修社区 - 创建账户
A 4-cycle straight shaft string trimmer manufactured by Troy-Bilt. This model is identified by TB675 EC.
starter cord won't retract back
my recoil cord won't retract
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
the pawls are broken. THewy are easy to replace. go to youtube and search "How to replace or repair my tb675ec pawls" https://www.youtube.com/watch?v=V7KduhbV...
bery detailed instruction I did it myself
完成的
添加一条评论
2个答案
最有帮助的答案
@Mike, txhunter2 , it sounds like you both may have a broken recoil. The spring has broken on txhunter2 recoil and on Mike's the flywheel engagement tang's have broken. At the link below I believe the whole recoil assy./housing can be replaced for just over $13.00. Good luck. See below links that may help repair/replace the required part. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.troybilt.com/equipment/ARIPar...
https://www.youtube.com/watch?v=2eSWBmhl...
这个答案有帮助吗?
得分 2
添加一条评论
Starter cord won't retract
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
txhunter2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 7,974
