跳转到主内容
Microsoft Surface Pro 系列二合一平板电脑的维修指南和信息。
573 个问题 查看全部
SSD replacement on Surface Pro
Hi guys.
Hope someone could give me a bit of advice regarding Surface Pro SSD replacement.
I was given a 1st Gen Surface Pro 256GB tablet with a dead SSD for free. The unit is in excellent condition and boxed, so I was quite keen to repair it. Using the iFixit guide I managed to remove the screen/digitizer without damaging the assembly or the ribbons.
Now my question is this - can I use any make msata SSD to replace the dead one? Are there any makes I should stay away from for reasons such as bios detection issues, booting problems, etc...
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The term "msata" means mini sata, so there should be no issues with any msata drive as it uses the standard sata interface, that said if I were to make a recommendation I would say get either a Samsung SSD or an intel one, preferably of the MLC or v-nand (also know as : 3D-vertical) flash type as they have the best speed to reliability and pretty good capacity as well
Here is a good one... you can change the capacity,
http://www.newegg.com/Product/Product.as...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Bailey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 543
