跳转到主内容
This computer was released by Asus in 2014.
Wont boot, stays in BIOS
I have an ASUS X205TA. It was working fine then all of a sudden an error came up that I don't remember what it said, then the BIOS screen (Aptio Setup Utility) showed up. Nothing I do will get me out of this screen. One thing I noticed, and I don't think it is good, is that under the BOOT menu, it says BOOT OPTION PRIORITIES, and there is nothing, and I mean nothing under that. Could this mean that the hard drive (32gb eMMC) failed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Hi, Don't know if it works but try plugging in a 'bootable' USB drive and see if you can boot off it or whether you even get the option to boot from it.
完成的
I was trying to find a bootable diagnostics program I could put on a USB drive. Do you know of any?
完成的
Hi @bluefish8879
Try this one. it is only a memory test not a complete diagnostics program. It's just to see if you can boot.
http://www.memtest86.com/
完成的
It happened to my x205ta also. It's worse when I called on Asus customer supported department and they said they will be charged me first, althought they have no idea of the problem.
完成的
添加一条评论
1个答案
First power cycle the computer and enter the bios, go to the boot order and see if you drive shows up, if it doesn't, open the computer and try reseating the drive (unplugging and plugging back in) if it still does not show if you can you can try plugging the drive into a desktop or external drive enclosure into a running computer and see if it recognizes it, if not its fair to say that your drive has died.
Also try booting from windows ## install media and see if it can find a problem
这个答案有帮助吗?
得分 0
3条评论:
Hi @ethreal1,
Bit hard to unplug the storage. I'm reasonably sure that it is mounted on the motherboard (eMMC)
完成的
Yes I do think you are right............. well..... I would try the windows install media and if Windows just went bad that would fix it... if not then storage dead....
完成的
Also if I remember right the windows install media can also check if ntfs is good so...
完成的
添加一条评论
添加你的答案
Joey Adams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 2,543
