跳转到主内容
加入维修社区 - 创建账户
Screen pixel problem weird pixels
MacBook Pro (13-inch, Late 2011)
2.8 GHz Intel Core i7
Intel HD Graphics 3000 384 MB
I need help suddenly my screen changes red pixels everywhere first i use the stuck pixel fix website by change screen background from green black blue white then it came back normal. However it's like a temporary fix. Now it's not working.
Is the problem with the LCD , Cable , or GPU ? and how to fix it ?
  • I tried using screen pixel fix over night (no use anymore) **
Edited ** I tried use air play from my Macbook Pro to My Apple TV here the image
Can i say this is my LCD issue ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
In my opinion this is the same issue that was covered in this program:
https://www.apple.com/support/macbookpro...
But the class action law suit did not include the 13" machines, so Apple is not fessing up to the issue.
Your best bet may be to call Apple and request a "Flat Rate Repair". This will most likely entail replacing the logic board with the offending GPU. If a future law suit develops you would then be eligible for a refund from Apple, A Flat Rate repair usually runs $357 which includes shipping and taxes. It generally takes four days including shipping time. For that price Apple will repair any and all defects found and give you a sixty day warranty. To initiate this call 1-800-MYAPPLE has your serial number ready and a credit card.
这个答案有帮助吗?
得分 3
1条评论:
after i tried air play my screen to my apple TV it seem fine.
完成的
添加一条评论
Sounds like you are either having GPU issues, or the pixels in the screen are on their way to being dead completely. I'd recommend taking it to an Apple Authorized repair facility to have them run hardware diagnostics to see if your logic board might be failing or if your screen is the issue
这个答案有帮助吗?
得分 1
1条评论:
If gpu or screen issues , Is there a way i can identify the problem by myself ? From where i live don't have apple repair facility.
完成的
添加一条评论
添加你的答案
hongranyden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 8,144
