Does the Air and the air 2 use the same doc connector?
Looking to repair an Air 2 doc connector but cannot find a replacement part. Are the doc connector the same on both Air and Air2?
The part number on the Air doc connector is 821-1716-A
No, completely different. Even the soldering pads are on different sides.
Basically you can forget about interchangeable parts in iOS devices expect for a few of them.
这个答案有帮助吗?
Hello,
Unfortunately the lightning connector is soldered onto the logic board on the iPad Air 2 and as such it is not compatible across devices.
If you take a look at the teardown, you will be able to see the issue.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 84
