跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
Does the Air and the air 2 use the same doc connector?
Looking to repair an Air 2 doc connector but cannot find a replacement part. Are the doc connector the same on both Air and Air2?
The part number on the Air doc connector is 821-1716-A
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
No, completely different. Even the soldering pads are on different sides.
Basically you can forget about interchangeable parts in iOS devices expect for a few of them.
这个答案有帮助吗?
得分 2
添加一条评论
Hello,
Unfortunately the lightning connector is soldered onto the logic board on the iPad Air 2 and as such it is not compatible across devices.
If you take a look at the teardown, you will be able to see the issue.
iPad Air 2 Teardown
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Snow 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 84
