跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Why isn't my battery charging after replacement?
Hey guys, I just replaced the iPhone battery with the new one. Everything went well during the replacement.
But now, I am facing a problem. The phone shows the correct charging symbol including buzzing when the cable is connected, but the battery is not charging...
What I have tried so far:
- Resetted the iPhone
- Reconnected all parts
- Tried the old battery
It is all similar to the guide. But still, the phone says that it is charging the battery, but in fact, the battery is not gaining more power.
Can anyone help me with this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
It could need a new charge port or it may be a problem with the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
Connect your old battery if it charges then that old battery is a dud.
I have had these batteries so many times.
这个答案有帮助吗?
得分 0
添加一条评论
Hi here is the solution please click on the below link and watch then tell him about your phone problem i am sure you will get a good solution
https://youtu.be/ItJnD-p2SEE
这个答案有帮助吗?
得分 0
添加一条评论
Check on the logic board near the battery connector. There are a few tiny components. Check the FL17 component, it goes to the gas gauge line. If it is missing, this will happen. If it is missing, send it to @jessabethany, she can fix anything :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Florian Meier 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 10
过去 30 天: 11
总计 117
