跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1697 个问题 查看全部
Faulty open button after teardown
I took my PS4 apart to clean out the fan and apply some better thermal paste. All successful, the device powers on and plays games nice and quiet now.
The only problem is the "open" button doesn't work any more. When touching it the CD doesn't eject. I've managed to eject discs by using the manual screw method, but would really like the button to work properly.
I've noticed on the inside of the lower casing there is a small metal contact that seems like it should make contact with something else. I've tried beinding it out a bit and putting it back together, but still doesn't work.
Has anyone had this issue or have any ideas?
Many thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
That metal piece you see contacts the copper pad on the green board on the disc drive. You need to bend it until it makes contact with that pad. I sometimes use a sharpie to color the metal pad then see the where the metal contact goes when I put the case on (there will be a line in the ink). That will tell you which way it needs to be bent.
Hope this helps..good luck!
这个答案有帮助吗?
得分 2
添加一条评论
You can eject the disc by pressing triangle then select remove disc
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sam Attwood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 93
