跳转到主内容
加入维修社区 - 创建账户
iRulu 平板电脑的维修指南和支持。
Locked out forgot password
Hi, I need to reset my password on Irulu 7 in tablet. Please advise. Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
8个答案
已选择的解决方案
On most Android tablets you are able to get into the Recovery mode by Pressing the power button and either volume up or down at the same time. you will want to make sure the tablet is off before holding the buttons down. once you get a menu you will be able to select Wipe User Data.
the volume keys are how you move up and down and the power button is how you select the option.
good luck.
这个答案有帮助吗?
得分 7
1条评论:
Thank you Mr. Candido Ortiz. I am trying to avoid Wiping User Data if possible. Any way around that?
由完成的
添加一条评论
I can't get pass the lock screen after so many tries I have to wait to try the pass word again.
这个答案有帮助吗?
得分 6
6条评论:
exactly!
由完成的
I. Can_t. get .my. Password. To. Work
由完成的
I. Can!T. get. My. Password. Working. Right
由完成的
this is not helpful at all!!! i tried to reset it several times and it still does the same thing
由完成的
I totally agree with you I tried over 50 times no luck. How about you?
由完成的
显示更多的1条评论
添加一条评论
My tablet expro X1s WiFi is not working.
And I forget my pattern please help me.
这个答案有帮助吗?
得分 2
添加一条评论
Does the Tablet have to be "Hold the Power Button Down" Off OR Just " Click the Power Button" Off?
bold text
这个答案有帮助吗?
得分 1
添加一条评论
It did not work for me
这个答案有帮助吗?
得分 0
2条评论:
My irulu tablet expro x2 was locked I reset my tab then I forget my old email and I try every option to open it but it can't please tell me how to open: it is also called bypass
由完成的
still locked out those buttons did not work
由完成的
添加一条评论
can you access the menu of your device?
这个答案有帮助吗?
得分 0
添加一条评论
I did get pass my Lock screen.but not I'm having problem with password Google send me a lot of code but the same things comes up sign in with the user email .doing it over and over.dont know what else to do.
这个答案有帮助吗?
得分 0
添加一条评论
Hold power key down ALONG with the volume down key together...must hold both down at the EXACT time!...wait until screen comes back on and release power key ONLY while still holding volume key DOWN until a menu appears on the screen...I have had to do this several times so don't be disappointed!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
islanena2008 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 8,589
