跳转到主内容
加入维修社区 - 创建账户
Hard drive won't mount, optical drive won't play
The only way I can get this machine to boot lately is if I boot with the HD from Firewire. And when I do so, the optical drive won't play any media; DVD or CD. Any ideas?
Update
Hi:
I've tried both suggestions and on either case System Profiler did not show the optical drive or the HD.. Is it possible that the IDE channel is broken. I'm thinking this because both the optical and the HD are connected to the same channel.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Wow, sorry to hear that. Is the hard drive confirmed good? If not, I'd make sure it works, and then I'd remove the optical drive, and get a known-good replacement hard drive cable, and see if that makes a difference. It's a nice machine, and I wouldn't give up on it until it failed to work with a known-good hard drive and hard drive cable. I'd eliminate the optical for the moment and just focus on the HD first.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi! From what you stated I'm guessing the optical drive is powered on and accepting media. If you go into About This Mac, does it show that an optical drive is connected? If so, and it's not reading media and/or kicking out all media, it may be a bad drive.
While you're booting from an external hard drive, I'd also go into About This Mac and see if it shows your local hard drive at all. If it does, you may want to go into Disk Utility, format it (if it will format), and then see if you can re-install the OS via target mode with the OS media in the other machine's optical drive.
Hopefully this will help. If not, let me know as many details as possible and I'll try to assist further. Thanks!
这个答案有帮助吗?
得分 1
1条评论:
Thanks for this. I can confirm that the hard drive works because it boots when in Firewire. Where can I get the hard drive cable? Thanks so much for your help.
完成的
添加一条评论
添加你的答案
Nesta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,581
