跳转到主内容
Resistance stuck at a high level
I have a Golds Gym Stride Trainer 350i and have owned it for 6 months, the past 3 of which I haven't used it. I tired to use it and it seems the resistance is stuck on a very high level making it almost impossible to use for a long amount of time. I've tried shifting up and down on the resistance, but nothing seems to help. I've looked inside and nothing looks like it is rubbing. Tension motor makes a humming noise when close to it, but that might just be because I've never been down that close to hear it before. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Did you buy it new?
完成的
Nope, but I used it for three months with no problems at all.
完成的
添加一条评论
2个答案
最有帮助的答案
Replace the batteries. The resistance motor wont work if batteries are low, even if display is working.
这个答案有帮助吗?
得分 1
2条评论:
I have the same problem, but I am using power cord, not batteries. Bike is 2 years old , and was working ok until yesterday.
完成的
If it's running on AC it could be 1) the resistance cable between the flywheel & the resistance motor is stuck on something, 2) the cable connecting to the resistance motor has jumped the pulley , or 3) the resistance motor is dead and needs replacement.
完成的
添加一条评论
Carmen, I have the exact same problem, on a totally different elliptical. After much research, it seems a common problem. Argh! Have you fixed it yet? I hear it can be that the magnets used to create the resistance get stuck together, or that the cable connecting the magnets breaks/comes out. I’m not on e to get in there and tear it apart, so there it sits! What’s your status now?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carmen M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 6,924
