跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s not turning on after getting hot
Hello,
I have an iPhone 6s and time ago I changed the battery in it, after some time the phone got extremely hot and now it won't pass the apple logo. I already changed the battery but the phone still won't boot (Now the new battery is drain and it won't charge nothing shows in the screen) I try restoring through iTunes but the phone is not recognize. I also check the voltage getting to the battery and it's 0.5V. Can a faulty charging port prevent the phone from booting even if the battery is fully charged?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like you received a faulty battery. You should not buy a battery from that distributor again and get a new battery form some other distributor.
这个答案有帮助吗?
得分 0
3条评论:
I changed the battery twice already. I actually thought it would work is there a chance any component is causing this?
完成的
Did this unit get wet? Does the battery connect to the main board or a separate board? It is a bad circuit on the connected board and it might be too expensive to repair/replace.
完成的
No the unit never got wet all sensors are fine (no corrosion). That's why I find it strange to have this issue. I will try another battery so I can confirm is a bad circuit (I hope that solves the issue)
完成的
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 107
