跳转到主内容
加入维修社区 - 创建账户
任天堂2DS是一台掌上游戏设备,作为任天堂3DS的入门版本而开发,在硬件上与3DS完全相同,但没有裸眼3D功能
Sleep Switch Stuck On
Ok, so I recently dropped my 2ds on the ground, and It wouldn't power on. I later went and figured out that the charging light WOULD come on, so I messed around with the sleep switch (fiddling it around) while pressing power. It came on, but went directly to sleep mode. How do I fix/replace the Sleep Switch?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would first suggest just opening the device and see how badly damaged the sleep switch is.
Best case, the switch just needs to be reset.
Worst case, it might need to have a new one soldered on.
Here's an image of where to find the sleep switch if/when you open the device. Follow this guide to remove the logic board for inspection: Nintendo 2DS Motherboard Replacement
You could possibly get away with desoldering the lid to the switch and inspecting the switch to see how damaged it is. Honestly though, I had a similar issue with a 2DS I fixed up. Reseating the outer switch to the inner fixed the problem.
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Red Bolt Media 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 89
总计 6,881
