跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
3 beeps and/or pressure applied to case causes lines or power shutoff.
Sometimes the computer will simply give me 3 beeps and not turn on. Other times it will boot up normally, but if I apply pressure to the case to the left of the trackpad or lift and move the computer around with any kind of velocity it will display lines like this and either go back to normal after releasing pressure or shut off:
I have tried every kind of RAM configuration and with different verified RAM sticks, and have determined it is not (at least simply) a RAM issue. Also, the battery is not bloated and only has 230 cycles
When the computer is booted up and left undisturbed, it functions normally.
Any wisdom you guys might share would be much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
See if it is doing the same thing with an external monitor.
完成的
添加一条评论
1个答案
最有帮助的答案
Hello.
It looks like you are facing with the cold soldering issue on the legs of the memory socket.
Re-soldering the legs will solve the problem.
这个答案有帮助吗?
得分 3
7条评论:
How do you do that?
完成的
@mayer, I think they mean to reflow the pins of the memory socket with hot air.
完成的
As soon as i can, i'll upload pictures of that. All you need is a microscope, a fine soldering tip, the flux and solder.
You have to remove the tapes covering the legs to get better view.
We face with this problem at least once a month.
完成的
You can't reflow that, the hot air will melt the plastic.
With hand, one-by-one.
完成的
I will be very interested to see the photos. I've not done a repair like this and have minimal soldering experience... Thanks @chiio
完成的
显示更多的2条评论
添加一条评论
添加你的答案
goodcyning 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 6
总计 114
