跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Full washing machine cycle salvage?
Co worker put IPhone 5s through full cycle with IPhone on. I've placed it in rice, should get the screwdrivers to open the phone come Tuesday and i'll take it apart and place it in rice for another few days. Placing the new battery I'm buying. Any take on if this is salvageable and if the battery doesn't work, how do I check logic board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Rice does not do anything for your waterlogged phone except let the water sit longer which causes further oxidation. What you should do instead is take the phone apart. Disconnect the battery and remove all of the components from the logic boards. Remove the covers from the logic boards, as they hold in the water, and run them through a good ultrasonic cleaner for 20 minutes. When finished, submerge the logic boards in 99% iso alcohol for a few minutes to displace the water. Let these dry completely. That should stop the oxidation which is what will cause further damage.
As for the damage that the water is done, it may be too expensive to fix. There are a few companies that can look at the logic boards and make that determination or possibly recover your data.
Good luck and avoid the Rice
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Eimert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 67
