跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
问题已关闭
Has anyone replaced their original hard drive with a 250GB SATA drive?
Has anyone replaced the original 1.8" 4200 rpm 80 GB hard drive in the original MacBook Air Model A1237 with the 250 GB 5400 rpm disk drive that Mayer found in the following thread:
Is it possible to upgrade MacBook Air hard drive beyond 120GB?
As I understand it the original 1.8" 4200 RPM 80 GB disk drive is an ATA drive that uses a PATA/ZIF connector.
The Toshiba MK2529GSG HDD1F07 is a 250 GB 5400 RPM Serial ATA drive.
Will the ZIF connector work with this SATA drive? Is the ZIF connector a converter of sorts? Will there be excessive heat? What can one expect in terms of performance?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The hard drive that mayer linked will not work in this computer. A ZIF connection is basically a ribbon cable, not compatible with the plastic SATA connectors. You can see the ZIF connector in step 15 of this guide.
这个答案有帮助吗?
得分 1
2条评论:
+ I'm going to agree with Alex on this one.
完成的
Thank you!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 6
总计 2,204
