跳转到主内容
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
89 个问题 查看全部
My Xbox 360 is overheating for no reason!
Hi,
this is the first time i have ever asked a question on ifixit , okay here it goes.
So my problem is that when i try to boot up my Xbox 360 e console (which is jtag)
it starts over heating for no reason , i mean i just started up the Xbox 360 and it starts overheating. my power button starts flashing red and the fan starts spinning
like crazy when i start it up. It booted up 2 to 3 times but after that it didn't even boot up. it just turns on and then it closes. Before the problem my jtag used to blink after every 6 seconds and now my jtag just blinks once and it starts over-heating , the flashing light on the jtag means it is trying to boot up.
THANK YOU
(in advance)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
From what I've read about JTAGing and modding the Xbox 360 in general, this sort of problem is not that uncommon. If its overheating, there may be an issue with original soldering done for the JTAG.
Here is what I would recommend trying:
1. Checking the soldering joints on the JTAG - are they neat and clean? In soldering, if the joints were done messily or the iron was to hot, it may have damaged some nearby components.
2. Try removing and replacing the thermal paste connecting the Heat sink to the CPU and GPU. In my experience, the factory thermal paste used in the original manufacturing of a lot of consoles are not great, to put it mildly. There is a good chance the original thermal paste has dried up reaching the end of its lifespan, so replacing it should fix the problem. You'll don't need anything to fancy - Artic Alumina thermal paste should do the trick. (Its made by Artic Silver, and you want the single syringe one, NOT the one that comes with two syringes. I believe you can get it here through iFixit, and its also the thermal paste typically sold with Xbox 360 RROD fix kits.) You'll also need the 2 Step Articlean to clean off the old thermal paste from the processor and heatsink, and prep the surface for the new paste. This can also be bought here on ifixit, along with most major computer parts and repair stores.
How to Apply Thermal Paste
Hope this helps!
- Ben
这个答案有帮助吗?
得分 2
2条评论:
Hi,
Ben i am really thankful to you . I really thought nobody will answer my question because i have a jtaged xbox 360.Well i think this is the solution i was waiting for. i will try both of the solutions to my problem.you will hear from me soon, in regards to my problem.
Hashir Adnan Hassan is eternally grateful.
完成的
Happy to help! I look forward to hearing the results.
完成的
添加一条评论
添加你的答案
Hashir Adnan Hassan 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 37
过去 30 天: 166
总计 20,252
