跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Battery seems to be damaged
A few days ago I dropped my phone from my pocket. It landed on the bottom left corner. And a few hours later the phone died but it said 55% near the battery icon before it shuts off. I plug my phone in the charger and a minute later the phone turns back on with 67% battery (at least it said so). I though everything would be fine but later that day the battery died again with roughly 60% charge. I tried to reboot the device by holding the power button and home button. The phone turned on and shut down after a few seconds. When I got home I put my phone in DFU mode and recover the phone because I though the jailbreak tweaks kills the battery. No hope. I run several Geekbench and here are the results it showed that it decades from 99% to 62% in half an hour. It also shows that when the battery reaches 83% it immediately dropped to 76%. I ended up wrapping my battery in newpaper and throw it in the freezer for 12 hours. No hope
P.S the phone dies when it reached 55% (half an hour usage) and it shuts off. When it turns back on it is at 67%
P.P.S Battery apps shows that my battery capacity is at 87%/89% (either of them). When I charged it overnight they shows that my battery is at 92%
P.P.P.S I didn't put adhesive at the battery. But it survived tons of drops. It is possible that a single drop can take out the battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
change battery also charging hub
完成的
添加一条评论
2个答案
已选择的解决方案
更换新的电池就可以了。网站iphone修复有教程。这个是电池老化的原因。
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
It's either a faulty battery or the battery gauge fuse / component chip has been chipped off / damaged. It's located above the battery connector for the iPhone 5s battery.
It's best that you try replacing the battery first as it's a lot cheaper and easier to do. If the same issues still occur you are probably looking at a board level repair which is not DIYable, you will need to take it to a repair shop that does board repairs. I unfortunately don't know what stores that do it.
Guide to replace the battery:
iPhone 5s 电池更换
You can buy the battery from the iFixit parts store here:
iPhone 5s Battery
iPhone 5s Battery图片
产品
iPhone 5s Battery
$29.99
这个答案有帮助吗?
得分 3
1条评论:
good...............
完成的
添加一条评论
添加你的答案
L HK 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 112
