跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
lcd repair gone wrong
i tried to replace iphone 3g lcd screen and now it will not turn on. i followed the video and now it does not respond when i turn it on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
also try plugging it into the wall and doing the reset.
这个答案有帮助吗?
得分 1
1条评论:
+ fixes lots of problems.
完成的
添加一条评论
also, you could try (assuming it's powered off) connecting it to itunes. this way it should power on even if the power button cable is damaged (but of course leaves you with the problem of switching it off again). after plugging in, wait a minute and see if itunes recognizes it. that would mean the problem is the lcd.
这个答案有帮助吗?
得分 1
1条评论:
+good point, or toggle mute on & off
完成的
添加一条评论
添加你的答案
Jessica Humeniuk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,300
