The rollers are not pulling the paper through for printing.
The rollers are spinning but the paper is not being pulled forward for printing.
I suspect the rubber on the rollers are worn out so they can no longer grip the paper.
You can spray this on the rubber and it will work again.
这个答案有帮助吗?
Thanks I'll give it a try
Canon printers have a function where they can self-clean their rollers. It might need further service, but it's worth a shot. See https://support.usa.canon.com/kb/index?p...
这个答案有帮助吗?
Why cant you just replace the %#*@ things?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 33
总计 4,763
3条评论
I'm also having this problem with a Canon MG4100 , I'm having to push the paper through to get it going, pain in the a**e ! Any advice would be much appreciated.
由 David Worthy 完成的
The rollers is not pulling on top feeder, can anyone help edible canon printer
由 valerie person 完成的
Solution is not to buy a printer with Canon on it. Replacing rollers is more practicle but these are disposible printers so not made for replacing parts only the garbage bag in the can.
由 jkutzer57 完成的
