跳转到主内容
The Blu Dash JR D140 cell phone was manufactured by the Blu company in 2013, their headquarters is Doral, Florida.
13 个问题 查看全部
says radio off when I try to make a call
Trying to activate the phone. The screen says removed sim card. The card is in but when you try to make a call the screen says "radio off" call not sent dial emergency #. Called Tag mobile, they said to try the sim card in another phone. We don't have another phone that takes the mini sim card. anyone with any ideas? This is a disabled client of mine, limited income, so has this phone and he needs it to work. Thanks to anyone who has an idea we could try.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
The sim tray may be damaged. Go to settings>about>status and see what you get for the cellular related info.
完成的
My phone network is not coming what to do
完成的
Can't make a call because radio off. What do I do please.
完成的
I .may phone I see sine Radio off
What this min and haw this affect may phone
完成的
Do you have a hey Google radio, turn it on then call all the numbers affected by radio off then when you've proved that they are now connected turn off First your mobile Then your hey Google, I don't know if it is the same with Alexa but this was my problem and I figured it out as I remembered I'd turned my hey Google radio off at the plug in the middle of the phone call, hope this helps
完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
the problem is probably that they already took down 2g towers this phone runs 2g so it would no longer work
这个答案有帮助吗?
得分 2
2条评论:
What do I do?
完成的
I have a BLU2. When this happens (Radio Off), I do a total reboot and on new start-up, problem solved. You can also try removing and resetting the battery.
完成的
添加一条评论
@Linda Liggett wriglesworth Since the problem is 2G towers, you will have to get a new phone. Would you prefer a smart phone or flip phone? What carrier do you use?
这个答案有帮助吗?
得分 1
3条评论:
My phone model is vivoY71
完成的
Please give me solution. I can not Call any one because it show radio off
完成的
@Most munni Khanom Get a 4G capable phone and get a new SIM card from your carrier.
完成的
添加一条评论
添加你的答案
pris 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 33
过去 30 天: 179
总计 16,158
