跳转到主内容
This Power Mac G4 has Mirrored Drive Doors.
How do I remove the processor from a MDD computer?
I want to remove the processor and mother board from my computer so that I can install a new motherboard and processor but I cannot figure out how to release the processor from the board.
Any written instructions or photo help files on this topic would be greatly appreciated, thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
This guide is incomplete but will get you down to the CPUs.: How do I remove the processor from a MDD computer?
Please tell us the specific MDD you have (on a plate on the back of the machine.
这个答案有帮助吗?
得分 2
2条评论:
完成的
完成的
添加一条评论
Hello Laurie,
First you need to discharge yourself - touch a metal surface of the MDD with your hand and right after you've done that you can continue safely.
*Edit : Remove the Heatsink*
the yellow box indicates the connector underneath.
1 - in these two ellipses go your thumbs. apply a bit pressure.
2 - index and middle finger go under the board and pull up the board gently. you work against the pressure of your thumbs and the force of the connector. but I find this quite comfortable.
Regards Jan.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Laurie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,462
