跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
Plasma tv with sound but no picture
I have a 65" Plasma Samsung TV that is only 3 years old and one day the screen just went black. There is sound and no cords were unplugged or loose but the picture was completely lost. There are indicator lights that it's working obviously since we still have sound but not sure where the picture disappeared to.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Jamie Russell what exact model is your TV?
完成的
添加一条评论
2个答案
最有帮助的答案
I have a 43" plasma that had the same problem. After experimenting with several boards I found that the Y sustain board was bad. It cost less then $70.00 to replace. Again, check out the videos available on You Tube; I call it You Tube University. You will find videos relating to Samsung Plasma tv's. Since they are mo longer making plasma tv's you might want to hold on to the one you got. Believe me you can fix it for less than a new comparable set.
这个答案有帮助吗?
得分 2
添加一条评论
Maybe the monitor is dead. It should be the time for you for buy a new one. I strongly not recommend to fix it because it's pretty hard if it's a superslim tv. most of the parts are soldered and not easy to take apart if you don't have any experience.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Jamie Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 13,132
