跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
PNY CS 1311 SSD doesn't work attached to internal HDD cable. Why?
I recently got a new SSD (PNY CS 1311 - 480 GB.) The drive itself seems good – it works fine when attached by USB to my MacBook Pro (MBP) and by USB and SATA to my PowerEdge SC440 and my girlfriend's Latitude E6540 – but I can't get my MBP to work with it when it's attached to the internal hard drive (HDD) cable.
Here are some symptoms when the SSD is attached to the HDD cable:
  • If I try to install OS X 10.11 to the SSD (GUID partitioned with 1 blank HSFS+ partition) using a USB installer, the partition on the drive is available as an installation target, but the installation fails with the error message: "An error occurred while preparing the installation. Try running this application again."
  • If I try to erase or partition the SSD (un-partitioned) using the USB installer's Disk Utility, I can see the disk but get errors like "Couldn't read to end of disk."
  • If I try to erase or partition the SSD (GUID partitioned with 1 blank HSFS+ partition) using Disk Utility in the USB installer, I get the error message: "Couldn't unmount disk."
  • If OS X is installed to the SSD, which I can do by attaching it through USB, and I try to boot, I get the question-mark folder.
None of these are a problem if the drive is attached by USB; when attached by USB, the drive can be erased, partitioned, installed/duped to, and booted from to run OS X without issue.
So far, I've tried:
  • Reset MBP NVRAM/PRAM & SMC.
  • Verified that the MBP EFI & SMC firmware are up to date.
  • Replaced hard drive cable with new one (from eBay.)
  • Verified that SSD firmware is up to date (thanks to Dan for this suggestion.)
Anyone know why this doesn't work or what I can do to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Your PHY SSD specs: PNY CS-480 GB 1311 SSD
完成的
添加一条评论
3个答案
已选择的解决方案
Per PNY tech support: this MBP doesn't support SATA II/III-only drives, which this drive is, so I wound up returning it.
这个答案有帮助吗?
得分 1
3条评论:
I'm very surprised! I've got Samsung SSD's in a few so theres something unique with the PNY drive. Sorry it didn't workout.
完成的
It's all good - I very much appreciate your help. FYI, the PNY dude claims a drive has to be SATA (I) compatible to work in this particular MBP and the PNY CS 1311 is only SATA II & III.
完成的
Update: This drive is a fixed SATA III (6.0 Gb/s) the issue is it won't play in a SATA II (3.0 Gb/s) system. PNY updated the drive but failed to update the spec sheet. It would have been smarter of PNY to update the model ID so the newer drive was not sharing the same model ID.
完成的
添加一条评论
最有帮助的答案
Your system's SATA port is SATA II (3.0 Gb/s) and this SSD is a dual speed drive SATA III (6.0 Gb/s) and drops down to SATA II (3.0 Gb/s). So from the specs you should be working!
So what could it be??? As you've already addressed making sure the systems firmware is up to date and you had replaced the drive cable (hopefully with a new not used cable) You've hit the top two issues.
So the only thing I can see here is the SSD's firmware. Now the rub...
You'll need to use a Windows based system to run the PHY tool to check it as well as update it if needed. Here's a link to the PNY firmware Update: Firmware Update.
Of course its possible you have a bad SSD here as well... Have you tried exchanging it yet?
这个答案有帮助吗?
得分 2
13条评论:
PNY Drive Utility on my girlfriend's Windows machine declares the drive not eligible for firmware upgrade and therefore (presumably) it's running the latest firmware.
完成的
I'm dubious that the SSD itself is "bad" since it works in every other machine I put it in, including other SATA II machines like my PowerEdge server. It may well be incompatible with this MacBook due to the MacBook not doing what it says, though! I'm not sure if it's right to return it on that basis, but perhaps that's what I'll be driven to; however, it'd be nice to figure out why it doesn't work before I do that, so I can get one that does work and edify the general public.
完成的
The replacement HDD cable was listed as new from a reliable supplier on eBay. I wouldn't bet my life that it was fresh from the HDD cable factory necessarily, but I'm disinclined to continue barking up that tree without some way to test the cable (other than installing another new one of maybe better provenance and hoping it works this time.)
完成的
Did the cable have peal off strips on the sticky surfaces? If not it was used. I've also gotten new damaged ones on eBay.
完成的
The drive doesn't care what system its in as long as the SATA standard is correct.
I'm with Mayer here if the PNY drive utility tells you its up to date and you have proved it works in other systems then the SSD drive is not the issue it has to be the drive cable!
完成的
显示更多的8条评论
添加一条评论
The issue in connecting to different machines using varied interfaces exists when the drive is connected. Computer system component designed as internal drives often perform a base configuration to match the installation environment. Once set it becomes part of the firmware rom and is locked into the hardware. I would have bet if you had tried to reconnect the drive by USB to the MBP it wouldn’t have been functional because the first “true” SATA connection was to the Dell Server and depending on what port it was connected to in the Dell it would have configured the drive accordingly (that is one of the items mentioned on the Dell server product page for the PowerEdge SC440)
这个答案有帮助吗?
得分 0
1条评论:
@wizbang_fl - SATA is a standard!
The issue here is the maker of the drive failed to correctly list in its spec sheet what version of the spec it was compatible.
Dell servers or any RAID system is a very different config where the the drives within a RAID set need to be the exact same.
完成的
添加一条评论
添加你的答案
Mike Sorice 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 11
总计 4,229
