跳转到主内容
带13寸显示屏的 MacBook Air 机型
3664 个问题 查看全部
Display connection is covered in tape
The display cable is covered all around with a yellow transparent tape. It is not attached to the socket. When i peeled the tape back the cable came with it. Could this be the source of my display problem. And no this has never been tampered with. I do not understand how it worked before. Should i connect and try before i proceed with display replacement. The mac was dropped and display went out.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you give us your exact model info. If you don't know you can check it here using your systems S/N: EveryMac
完成的
That machine has been worked on. Apple did not do that.
完成的
添加一条评论
1个答案
已选择的解决方案
ok I decided to stop disassembly at that point and plugged in the cable. I then reassemble the air and booted up to check the screen.
all I got was some lines across the screen and then it went out. At that point I decided to replace the screen I received from Ifixit and rebooted the system again and voila! there was my computer. I did make a boo boo though I damaged the blower connection and had to order a new one :(. I was surprised the system booted up to show me the screen worked. I had to shut off before I overheated the cpu. Thanks for the response guys. Is it usually that hard to get that blower connection to connect? Yep I unlock the clip.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
asini1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 75
