Upgrade iMac 2010 from i3 3.2 to i5 3.6
I upgraded my iMac 2010 i3-3.2 to i5-3.6, but has been very slow , any ideas? Thanks.
Geekbench 3.4.1 Tryout for Mac OS X x86 (32-bit)
Single-Core Score 908 Multi-Core Score 1991
OS X El Capitan
Version 10.11.6
iMac (21.5-inch, Mid 2010)
Processor 3.6 Ghz Intel Core i5
Memory 12 GB 1333 MHz DDR3
Graphics ATI Radeon HD 5670 512 DDR3
6条评论
Can you give us the exact model & specs of the processor chip you put in.
由 Dan 完成的
This is the specs with the upgrade:
System Information
Operating System Mac OS X 10.11.6 (Build 15G31)
Model iMac (21.5-inch Mid 2010)
Processor Intel Core i5-680 @ 3.60 GHz
Processor ID GenuineIntel Family 6 Model 37 Stepping 5
由 Eduardo Silva 完成的
Where did you get this CPU and was it an iMac pull?
由 mayer 完成的
Here's the Specs for your original CPU:
- i3-550 Processor (4M Cache, 3.20 GHz)
And here is the specs for your replacement CPU:
- i5-680 Processor (4M Cache, 3.60 GHz)
Is this correct?
由 Dan 完成的
I did the same, the iMac didn't even boot properly, I had to use Safe Mode to Log with 10.13.6 . I've tried with I5-680 and I5-650, it does the same thing bootloop 'till I put in the original I3-540 which still works of course.
I was thinking to a microcode update for the mobo but I guess Apple puts these updates in the normal os update...Fact is when I put the upgrade cpus no matter which one, the machine won't boot!
Any suggestion?
EDIT: TDP is 73W
由 federicolovato 完成的
显示更多的1条评论
