跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
Trackpad won't click otherwise works great.
MacBook 13" Unibody late 2009 A1342
The trackpad works great but does not click on left or right side. The battery is good, no swelling. Should I try to replace the springs or do I need to replace the trackpad?
If I adjust the detent screw it did help a little, but still did not click properly. Thanks for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I took it apart and gently manipulated the trackpad by bending the metal plate on back upwards. It now clicks fine and all features work great. We will see how long it lasts... but so far over two weeks now.
完成的
添加一条评论
1个答案
已选择的解决方案
At his point I would remove it and see if there is something that has gotten under the lip of the pad preventing it from being properly depressed.
Apple Part #: 922-9551, 922-9175, 661-9551
Here's the guide: MacBook Unibody Model A1342 Trackpad Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dennis Medlock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 262
