跳转到主内容
Model M7886 / 450 MHz or 500 MHz PowerPC 7400/7410 (G4) Processor
17 个问题 查看全部
Why won't my cube power up
My cube wont power up. I cam home the other night and something had fallen on surge protector switch and cut of the power on that protector. My Cube was also off and would not restart. since then I have removed the memory twice, I have removed the DC card and gone through several procedures trying to get it to start. I bought another power adapter, still it would not power up. Can anybody out there help me!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Reset the PMU via the CUDA button. Look at the third picture down to find its location: http://support.apple.com/kb/ht1939
这个答案有帮助吗?
得分 2
2条评论:
完成的
完成的
添加一条评论
Having same issue HELP
这个答案有帮助吗?
得分 0
添加一条评论
I found that the plastic housing can cause a cube not to start. If you press the power on button on the top and it does not light up the housing could be the problem. I have a great working cube and last week I got another one due to the seller listing it so cheep. It would not turn on the seller said is the reason he was letting it go so cheep. I tried every thing to get it to start, nothing worked. On a lark I put the main unit in my working cube and guess what it started up just fine. I do not know why and have not found any info on this kind of problem with the housing preventing a cube from starting on the web. You should also know I put my working cube main unit into the bad housing and it would not start. Maybe someone knows why this happens? I hope this info can help.
这个答案有帮助吗?
得分 0
添加一条评论
I think I had this problem back when I was still refurbishing my cube, and I believe the problem was bad ram.
Do you have multiple sticks? If so, try one at a time to isolate a possible bad one.
Here is a link to the service manual for the cube:
http://tim.id.au/laptops/apple/powermac/...
It has troubleshooting stuff at the end, and has been the best resource for me when working on my cube.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
spa11ow 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 2,527
