跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Kenmore Microwaves.
Repeats 1234 error code on display screen
We had a severe storm which resulted in a power outage for about 24 hours. When the power went on, our microwave started to run though numbers on the display screen. 1 2 3 4. It runs through each number about 4 times until it stops on 1.
Update (07/24/2016)
It's a Kenmore model number 721.80032700.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
What microwave is it. Make and model number please
完成的
Thank you, I will try it.
完成的
That worked! Thank you for your help.
完成的
Glad I could help ;-)
完成的
添加一条评论
1个答案
已选择的解决方案
Sometimes shutting off the circuit breaker that the microwave oven is connected to for 30 seconds will clear the fault, error or function code; however, there are some cases when further service may be required.
http://products.geappliances.com/applian...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jackie Dobransky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 321
